You are here: PSPad forum > English discussion forum > Re: Autocomplete with arguments
#1 Autocomplete with arguments
Posted by: kenny1930 | Date: 09/01/2014 13:31 | IP: IP Logged
Hello there smiling smiley
i'am using pspad with php.
I wonder if it is possible that the autocomplete function shows me not only the
complete function name but also the parameters?
I know with STRG SPACE i get what i want but already in my document. Is this feature also possible in the advice window which appears when autocomplete is activated and i do some keystrokes?
Maybe i didn't see something in the settings?
Thanks in advance,
Kenny
Edited 1 time(s). Last edit at 09/01/2014 13:31 by kenny1930.
#2 Re: Autocomplete with arguments
Posted by: pspad | Date: 09/01/2014 14:17 | IP: IP Logged
Autocomplete is general function. If doesn't offer you functions, but any word from document.
To get list of functions, you can use code explorer (Shift+Ctrl+E) or Code clips (Ctrl+Space) you mentioned.
#3 Re: Autocomplete with arguments
Posted by: KennyMax | Date: 08/13/2017 15:03 | IP: IP Logged
Hello everyone!
In a new script I've put some include:
include("func.php");
include("main.php");
Now, if I start writing the name of a function in func.php in my script, should not I suggest the function I'm going to write like completion?
Thanks a lot for the help and congratulations for the program that is great!
#4 Re: Autocomplete with arguments
Posted by: pspad | Date: 08/13/2017 15:23 | IP: IP Logged
PSPad doesn't do parsing of all functions in all libraries you include.
Can you imagine it to do it generally in all languages? In include can be another include and it can contains another include... Each language has own syntax e.t.c.
