You are here: PSPad forum > English discussion forum > Wrong compare result
Posted by: Timon34 | Date: 2014-07-07 05:18 | IP: IP Logged
Try to compare 2 files
1.txt with text in it:
# 12345
and
2.txt with text in it:
# 12345
(the only differ - quantity of spaces)
PSPad 4.5.8 (2485) thinks that files have no differences at all! But it is not so.
Posted by: Timon34 | Date: 2014-07-07 05:33 | IP: IP Logged
(in 1.txt after # there is only one space)
and
(in 2.txt after # there are two spaces)
Sorry, but forum cuts extra spaces!
Posted by: pspad | Date: 2014-07-07 05:49 | IP: IP Logged
in the program settings you can set if diff tool ignore spaces e. t. c. this option is on as default
Posted by: Timon34 | Date: 2014-07-07 07:30 | IP: IP Logged
Thanks a lot! I found that setting. But I think that "Ignore Char Case" and "Ignore Blank Space" must be switched off by default.
Posted by: pspad | Date: 2014-07-07 18:00 | IP: IP Logged
Each user has own opinion. Default settings comes from the common ussage of most users
