You are here: PSPad forum > English discussion forum > Re: insert a text line each x lines in a txt file
Posted by: Esgrimidor | Date: 2014-06-22 15:24 | IP: IP Logged
How can i insert a line with text in a txt file with a rule : by example each 15 lines of the original txt file.
By example :
insert "lapsus" each 15 lines while exist the corresponding line.
Best Regards
Nice program indeed
Posted by: Esgrimidor | Date: 2014-06-22 16:18 | IP: IP Logged
And in reverse mode :
Delete a line every x lines
By example
x5
line 5
line 10
line 15
etc while .not. eof
Best Regards
Nice program indeed
Posted by: pspad | Date: 2014-06-22 16:35 | IP: IP Logged
There are 2 ways:
Copy text to clipboard
Macro
1. record macro - move 15x down and paste text
2. let macro run any times you need
The same you can do for delete each 15th line
Script
write script using PSpad scripting. PSPad scripting uses Windows Scripting Host and you can use any scripting language what is supported and presented in your operating system. In default JScript and VBScript.
Posted by: Esgrimidor | Date: 2014-06-23 10:37 | IP: IP Logged
Understood
Best Regards
Nice program indeed
