You are here: PSPad forum > English discussion forum > repetition count for inserting text into files
Posted by: m.ibng | Date: 2014-06-17 14:12 | IP: IP Logged
In the 'Insert Text into Lines...', please add a textbox or the like where the user can input how many times the text will be displayed.
If incremental number is to be inserted, how many times it will be incremented and displayed. Please also add an option to choose the line
where the cursor is as the starting line for the insertion. Currently, if not in column mode, even if the cursor is in line 6 the text will be inserted
from line 1 to the last line.
Posted by: pspad | Date: 2014-06-17 17:50 | IP: IP Logged
Select lines first, this function will insert text to selected lines. It's more comfortable and user friendly than count lines and write how many times you want to insert it into dialog
Posted by: PEdit | Date: 2014-06-30 05:42 | IP: IP Logged
Btw. SynWrite has similar dialog. It has option "How many times to insert". And start line is used Ok.
