You are here: PSPad forum > English discussion forum > file info
file info
#1 file info
Posted by: m.ibng | Date: 2014-06-17 14:10 | IP: IP Logged
The 'Detailed statistics' in the file info dialog counts not only the number of words, lines and characters but also
the number of occurrence of each of the letters and words. Maybe this slows down the counting process so why not provide a
'Less detailed statistics' that will count only the number of words, lines and characters. Maybe some users need only this infos
and they might benefit from the speed improvement if there is.
By the way, the 'Detailed statistics' isn't displayed for 'small' files (since it isn't needed, it seems). What is the
max size of these 'small' files?
#2 Re: file info
Posted by: pspad | Date: 2014-06-17 17:46 | IP: IP Logged
If file is big, there is button to start detailed statistic manually.
For small files detailed statistic is counted automatically.
I Don't think so it takes a long time. Can you give me some example?
