You are here: PSPad forum > English discussion forum > [Solved] Word wrap commit changes
Posted by: foxidrive | Date: 2014-05-12 12:48 | IP: IP Logged
I would like to open a file, use word wrap, and commit the wrapped line changes with CR/LF line ends. Is this already possible, or can it be added as a feature?
I understand that word wrap has some issues - but maybe this simple use case could work?
I have "Wrap (soft) with Right Edge" enabled if that matters, because that is where I would like the wrapping to be commited to.
Thanks
foxi
First post - I hope I haven't stepped on anyone's toes.
Edited 1 time(s). Last edit at 2014-05-12 13:28 by foxidrive.
Posted by: pspad | Date: 2014-05-12 13:03 | IP: IP Logged
You can wrap lines using right edge + menu Format / Block format
Posted by: foxidrive | Date: 2014-05-12 13:24 | IP: IP Logged
Thank you for your reply.
EDIT
I have realised that I have to reformat the paragraphs, and not use Block Align, which justifies too.
Many Thanks
foxi
Edited 2 time(s). Last edit at 2014-05-12 13:28 by foxidrive.
