You are here: PSPad forum > English discussion forum > a way to consider first column number 0 instead of 1 ?
Posted by: secarica | Date: 2014-04-24 14:47 | IP: IP Logged
At present, when the cursor stays at ruler position n, the counter in status bar shows n+1. Thus if I want to tab -> tab -> tab to start writing at column 40, I have to consider column 41 in the status bar. Or, if I am at column 2 the status bar says 3, if I position the cursor at exact number 10 under the upper ruler the status bar says 11, etc.
Is there a way for the column number in status bar to start from 0 instead of 1, same as the numbering in the upper ruler ?
Thank you,
Cristi
Edited 2 time(s). Last edit at 2014-04-24 14:52 by secarica.
