You are here: PSPad forum > English discussion forum > Re: Problem with downloading
Posted by: hector | Date: 2014-04-23 08:54 | IP: IP Logged
Hi ,
I used to use PSPad Editor on my PC ( OS : Windows XP ) with no problem and now I've upgraded to Windows 8.1 .
My Problem is that I can not download the Editor and every time I try to download it , a different Program other than PSPad will be downloaded .
What is wrong ?!
Posted by: pspad | Date: 2014-04-23 09:30 | IP: IP Logged
What do you mean? Can you provide any screenshot?
You can download ZIP version (portable), simple unpack it and create link. PSPad doesn't need installation.
Posted by: hector | Date: 2014-04-23 10:23 | IP: IP Logged
Thanks for the reply .
The Problem has been solved by downloading the ZIP version and running the Setup .
Of course , the Editor must be installed on the PC , so that I can use it as it was by my Windows XP .
