You are here: PSPad forum > English discussion forum > PSPad hangs badly when ftp connection is lost or unstable
#1 PSPad hangs badly when ftp connection is lost or unstable
Posted by: Alex | Date: 2014-04-13 12:58 | IP: IP Logged
In some cases it bacame completely unresponsible until it upload certain file to the ftp.
It started long ago actually. If connection is good then all working fine, but sometimes it really hangs.
May be there is a way to tune up it? What is the passive mode checkbox? Is it nesessary to use NOOP commands etc?
#2 Re: PSPad hangs badly when ftp connection is lost or unstable
Posted by: pspad | Date: 2014-04-13 13:55 | IP: IP Logged
You can decrease timeout from default 30s.
Active/Passive FTP mode: www.jscape.com
Kepp connection alive using different command is usefull for servers what disconnect client after some time of inactivity. You need to find what command works for your server or let PSPad use command randomly.
#3 Re: PSPad hangs badly when ftp connection is lost or unstable
Posted by: Gav | Date: 2014-05-21 15:00 | IP: IP Logged
Can someone tell me where in PSPad to configure FTP settings? I've read the Help page which describes these settings, but doesn't say where to change them smiling smiley
#4 Re: PSPad hangs badly when ftp connection is lost or unstable
Posted by: pspad | Date: 2014-05-21 15:11 | IP: IP Logged
Left panel / FTP
Click on the FTP connection button on left panel toolbar and you will get list of FTP connections. You can add, modify, delete, ...
