You are here: PSPad forum > English discussion forum > Re: How to turn off autocomplete?
Posted by: therium | Date: 2014-03-31 14:30 | IP: IP Logged
PSPad 4.5.7
How do I turn off autocomplete? I'm writing a Perl program and this box full of words keeps popping up when I'm typing a command. I couldn't find this info in the help file either even though I found 2 entries for variations of "auto complete", which took me to 2 different help pages.
Thanks.
Edited 1 time(s). Last edit at 2014-03-31 14:31 by therium.
Posted by: vbr | Date: 2014-03-31 14:45 | IP: IP Logged
therium:PSPad 4.5.7How do I turn off autocomplete? I'm writing a Perl program and this box full of words keeps popping up when I'm typing a command. I couldn't find this info in the help file either even though I found 2 entries for variations of "auto complete", which took me to 2 different help pages.
Thanks.
try to set
Program settings: Editor (part 2): Autocomplete delay [ms]. to 0
hth,
Posted by: almo | Date: 2017-08-30 19:19 | IP: IP Logged
Hi!
It's autocompleting HUGE chunks of text I must then delete even though I have autocomplete set to zero.
I type "if" and I get this:
IF [NOT] EXIST filename (command) [parameters]
IF [NOT] (string1)==(string2) (command) [parameters]
IF [NOT] ERRORLEVEL (number) (command) [parameters]
Rem Allows for conditional operations in batch processing.
Posted by: pspad | Date: 2017-08-30 19:37 | IP: IP Logged
It looks like you change run clip command shortcut from shift+space to space only or you used to write shift+space instead of space.
Open program settings / keymap and remove shortcut for run clip
