You are here: PSPad forum > English discussion forum > Compiler Settings/External applications: Variable for main project file
Posted by: padfox | Date: 2014-03-30 00:47 | IP: IP Logged
is there a variable for using the main project file as parameter? When I press the "inf" button in the Compiler Tab only the executable is shown.
BTW, that "inf" button should be added to the External applications tab and to the Project settings/Compiler Tab, External applications tab.
Many thanks and greetings
padFox
Posted by: pspad | Date: 2014-03-30 18:13 | IP: IP Logged
If any file is marked as main project file, PSPad will send into compiler this file instead of the current file.
So use parameter for file, e.g. %File%
If there is filled in parameter (filed under compiler exe), PSPad will show you whole path include real file name. Of course in case any file or project is open.
