You are here: PSPad forum > English discussion forum > Re: Word wrap issue ... again
#1 Word wrap issue ... again
Posted by: Svibrager | Date: 2014-03-25 06:29 | IP: IP Logged
I'm having a problems with word wrap (latest ver):
1. constant crashes (Access violation at address 004FD264 in module 'PSPad.exe'. Read of address FE1604CC).
2. slow response when going into word wrap mode or when changing the line break length in long lines.
#2 Re: Word wrap issue ... again
Posted by: pspad | Date: 2014-03-25 06:39 | IP: IP Logged
Serious wordwrap issue is related to Windows 8.1 upgrade. I am stil in investigate process, cause I don't know what was changed from the MS side.
#3 Re: Word wrap issue ... again
Posted by: Svibrager | Date: 2014-03-25 06:40 | IP: IP Logged
My OS - WinXP.
#4 Re: Word wrap issue ... again
Posted by: pspad | Date: 2014-03-25 06:57 | IP: IP Logged
Try to switch off highlight matching brackets (program settings / Editor 2)
#5 Re: Word wrap issue ... again
Posted by: Svibrager | Date: 2014-03-25 07:38 | IP: IP Logged
Ok. will reply after test.
#6 Re: Word wrap issue ... again
Posted by: code tzar | Date: 2014-04-19 03:04 | IP: IP Logged
Having this same issue with Win 8.1 update.
I turn off word-wrap, it's fine.
@pspad, your trick to turn off highlighting solved the problem, but highlighting is one of the best features of your app!! haha.
Would love to have this fixed, will help any way I can.
#7 Re: Word wrap issue ... again
Posted by: pspad | Date: 2014-04-22 04:40 | IP: IP Logged
I didn't suggest to turn off highlighting, only the switch off highlight matching brackets if you use the wordwrap mode.
Install the latest build from the developer forum
#8 Re: Word wrap issue ... again
Posted by: code tzar | Date: 2014-04-23 00:09 | IP: IP Logged
That's what I meant, sorry. Yea, I turned off matching brackets highlighting and it fixed.
I now am running latest build (2471) and no more crashing with matching brackets highlighter. Thanks!
#9 Re: Word wrap issue ... again
Posted by: code tzar | Date: 2014-04-23 01:07 | IP: IP Logged
I am noticing now that the bracket highlighter does not work if word-wrap is turned on, only when wrap is off.
