You are here: PSPad forum > English discussion forum > Re: Getting complete word on caret via script
Posted by: Crow | Date: 2014-03-06 16:51 | IP: IP Logged
Is there a method which would return complete word which is on caret? I've read the documentation but there seems to be just method which return selected text. I wan't to write script which works with whole word without need to select it first (similar to how Find function works in PSPad).
Posted by: pspad | Date: 2014-03-06 17:21 | IP: IP Logged
You are right, there is no direct possibility to select word under cursor.
You can partially replace ith with 2 editor commends: ecWordLeft and ecSelWordRight, but it will mark all up to begin of the next word.
I will add command to select word into scripting
Posted by: pspad | Date: 2014-03-06 17:42 | IP: IP Logged
Forgot the last answer.
The correct answer is to use editor command ecSelWord. I will update readme.rtf in the Script root, cause this command is missing there
set obj = NewEditor()
obj.assignActiveEditor()
obj.command("ecSelWord")
