You are here: PSPad forum > English discussion forum > Re: Goto into Code Explorer by shortcut
Posted by: Anonymous User | Date: 2014-02-26 09:14 | IP: IP Logged
I would to know if is possibile to have a keyboard shortcut (such as ALT-L)
to go into Code Explorer when it's shown.
ALT-L would be right: this goes from code, to log window, to left panel with the tree of opened files, to the code explorer and then return to the main code window.
Also, I would to know how I can assign a keyboard shortcut to refresh the code explorer panel. I write php often and the code explorer does not update itself automatically when I write new function or variables. So, I must remove my hands off from keyboard very often to take the mouse and then click on refresh icon.
With these two improvements, PSPAD is the best editor for me (that I use since many years).
Thanks in advance.
Edited 1 time(s). Last edit at 2014-02-26 09:14 by r.bonacasa.
Posted by: Anonymous User | Date: 2014-03-31 09:07 | IP: IP Logged
I would appreciate that someone answer to my question.
Why none does not reply?
Thanks in advance.
Posted by: pspad | Date: 2014-03-31 09:20 | IP: IP Logged
Sorry, I was several days out.
ALT+L switches between main form (common ide) and Child form (document).
If you press Alt+L, focus is moved to left panel. With TAB key you can switch between individual main window parts. So Alt+L followed by TAB will set focus to Code explorer
Posted by: Anonymous User | Date: 2014-03-31 10:01 | IP: IP Logged
Ok. I didn't tried TAB.
Perfect!
And then, to refresh the code explorer by a shortcut?
Thanks in advance.
Posted by: pspad | Date: 2014-03-31 10:42 | IP: IP Logged
I have to redesign it to add possibilities directly go to tools and manipulate with them.
There is a way now, but with keyboard only - call context menu and Refresh menu item.
You can call context menu with special key on the right from spacebar or Shift+F10
I know, it's too much keys to press to reach what you want already
