You are here: PSPad forum > English discussion forum > Re: Suggestion / wish for UNIX shell syntax highlighter
Posted by: dirks | Date: 2014-02-18 15:10 | IP: IP Logged
The words "case" and "esac" should be highlighted like "do" and "done". This should be easy
Only if possible:
sh/ksh/bash-like UNIX shells have a more complex syntax and it would be very helpful if more parts could be highlighted.
The full syntax for "if" is
if ...
then
[elif ...
then
[else
fi
Now, only the "if" and the "fi" are marked as belonging together. It would be nice if the "then"s and all optional parts in between were highlighted, too, because it is too easy to write
and forget the "then" after the "elif". Also, when you have nested "if"s, it would be good to see which "elif" or "else" belongs to which "if ... fi"
if ...
then
elif ...
fi
I know nothing about the internal highlighters, are they written by hand or do you use some publicly available module? In the latter case, I might be able to help if I knew what it is
Posted by: pspad | Date: 2014-02-18 19:18 | IP: IP Logged
There is a limitation for pair of the words to highlight. I can't highlight several words at once
Posted by: dirks | Date: 2014-02-24 17:13 | IP: IP Logged
Ok. Then the actual behaviour is the best, of course.
