You are here: PSPad forum > English discussion forum > Error opening a file ?
Posted by: deteklover | Date: 2014-02-15 02:44 | IP: IP Logged
I rescently have an error on some network file when I want open them.
Here is the log :
The message says :
Cannot create file "C:\Temp\------.php". Accès refusé.
Exception class: EFCreateError
Exception address: 004237B9
Stack list, generated 15/02/2014 06:38:41
[004237B4] Classes.TFileStream.Create + $A4
[0040457F] System.@ClassCreate + $7
[004236EC] Classes.TFileStream.Create + $20
[00676C74] ftpsend.TFTPSend.RetrieveFile (Line 1016, "FTPSend.pas" + 12) + $12
[00402B55] System.@FreeMem + $5
[0067EBB8] uPSPadFTP.TPSPadFTP.LoadSaveFile (Line 669, "uPSpadFTP.pas" + 5) + $9
[0068D88D] uFTP.TfFTP.OpenFTPFile (Line 698, "uFTP.pas" + 31) + $1D
[0068C901] uFTP.TfFTP.listFTPDblClick (Line 347, "uFTP.pas" + 35) + $18
[00489425] Controls.TControl.DblClick (Line 4710, "Controls.pas" + 1) + $14
[00489588] Controls.TControl.WMLButtonDblClk (Line 4751, "Controls.pas" + 4) + $C
[00489270] Controls.TControl.WndProc (Line 4645, "Controls.pas" + 53) + $6
[0048D98B] Controls.TWinControl.WMParentNotify (Line 7184, "Controls.pas" + 3) + $6
[0048C2CF] Controls.TWinControl.WndProc (Line 6342, "Controls.pas" + 33) + $4
[0042ADA8] Classes.StdWndProc + $14
[0048C135] Controls.TWinControl.IsControlMouseMsg (Line 6295, "Controls.pas" + 9) + $16
[00468CFA] ComCtrls.TCustomListView.WndProc + $72
[0048BF4C] Controls.TWinControl.MainWndProc (Line 6237, "Controls.pas" + 3) + $6
[004A1BE1] Forms.TApplication.StopHintTimer + $15
[004A0F1B] Forms.TApplication.ProcessMessage + $83
[004A0F52] Forms.TApplication.HandleMessage + $A
[004A1172] Forms.TApplication.Run + $96
[006F9BFB] PSPad.PSPad (Line 88, "" + 52) + $7
Program : D:\Program Files\PortableApps\PSPad editor\PSPad.exe 4.5.7 (2450)
System : Workstation x64, Version: 6.2, Build: 23F0,
Processor: Intel, Intel(R) Core(TM) i7 CPU Q 720 @ 1.60GHz, 1600 MHz MMX
Display : 1366x768 pixels, 32 bpp
Active Controls Hierarchy:
TListView "listFTP"
TfFTP "fFTP"
TTabSheet ""
TPageControl "PageExplorer"
TPanel "panelProject"
TfPSPad "fPSPad"
Is anyone have same problem ?
How can I resolve it ?
Thnaks for any help
Posted by: pspad | Date: 2014-02-15 06:56 | IP: IP Logged
Does the folder C:\Temp\ exists?
I guess you set wrong path for FTP files in program settings\backup for FTP files
Or maybe the file contains chars what your operating system isn't able to handle
Download tyhe latest build from the PSPad developer forum, extract and replace existing files
Posted by: deteklover | Date: 2014-02-17 04:53 | IP: IP Logged
The C:\Temp already exist and I have full right in it.
I have the latest stable version.
Is it really necessery to install the dev. version ?
Is there another solution because this append recently and I use pspad despite a while !
Posted by: pspad | Date: 2014-02-17 05:22 | IP: IP Logged
As I wrote you, the file can contains chars what can't be handled by operating system. I don't know the file name.
Another reason - the file already existis in this folder and is locked with some other application and PSpad can 't write into this file.
There can be several reason and from the log I know only PSPad can't write file downloaded from your FTP into this folder.
You can try:
download the developer build
rename or backup your current PSPad.exe and put there PSpad.exe from the developer build. You can anytime return it back.
