You are here: PSPad forum > English discussion forum > Request for keyboard shortcuts
Posted by: PhilJollans | Date: 2014-01-19 13:12 | IP: IP Logged
Jan, I would love to have keyboard shortcuts to move through the results in the "Search results" and "Search in files results" windows.
Ideally I would like shortcuts to:
- switch to the search results window
(where I can then move up and down with the arrow keys)
- go to next search result
- go to previous search result
I would be happy with an unusual key combination, because I know most people will not need this feature.
Thanks for a great tool. I use it a lot.
Phil
Posted by: Manfred62 | Date: 2014-01-19 17:11 | IP: IP Logged
hmm, you mean 'F3' and 'Shift+F3'..?
PSPad 4.5.9 (2525)
Posted by: pspad | Date: 2014-01-19 17:28 | IP: IP Logged
As I understand, he needs shortcuts to go through search in files results.
Just now is possible to use Alt+L to jump into Search results field and use arrows to go through results, enter will open file and jump into appropriate line
Posted by: PhilJollans | Date: 2016-11-19 08:45 | IP: IP Logged
Sorry I didn't react to the replies. I probably did not set the option to get an email notification.
I did mean shortcuts to go through the search results.
I was not aware of the shortcut Alt-L. I have been using the mouse to switch into the search results.
Now I know that I can select the next result with Alt-L, Down, Enter. That is probably better than using the mouse.
I would still love keyboard shortcuts, like Alt-PageDown and Alt-PageUp to move through the results, showing each one in the editor window.
Phil
