You are here: PSPad forum > English discussion forum > BOMs for UTF-8 and UTF-16
#1 BOMs for UTF-8 and UTF-16
Posted by: tmpad | Date: 2014-01-18 23:11 | IP: IP Logged
I searched the forum for BOM related issues but did not find a sufficient answer.
Config:
Default CP for files opening: Menu format settings
Ident bytes in UTF-8 coding: Checked.
Check Menu | Format | UTF-16 LE
Create a new file and the status line says UTF-16 LE. In Hex Edit Mode the BOM is "FF FE". OK.
Check Menu | Format | UTF-8
Create a new file and the status line says UTF-8. In Hex Edit Mode the BOM is also "FF FE", but the BOM for UTF-8 is "EF BB BF".
Isn't this a bug?
#2 Re: BOMs for UTF-8 and UTF-16
Posted by: pspad | Date: 2014-01-19 09:47 | IP: IP Logged
There are 2 HEX modes (se the help). If you open file as text and switch to hex mode, you will always see content in UTF-16LE - it's a image of memory.
It you want to see real file content, open file directly in HEX editor (right mouse in Windows explorer or menu File / Open in Hex editor)
#3 Re: BOMs for UTF-8 and UTF-16
Posted by: tmpad | Date: 2014-01-29 20:09 | IP: IP Logged
To be frank, it's not really clear from the help, that there are two different modes.
1) You say, that when I choose "View | Hex Edit MODE", I will see the content in UTF-16LE. When I do so with a UTF-8 encoded file, the status line still reads UTF-8, not UTF-16LE.
2) The hex code starts with a UT-16LE BOM. BOMs are meant for files, but not for memory images.
3) When I overwrite the BOM with a blank, code 2000, and switch back to the normal view, each charater is now followed by a blank.
I consider this as bugs.
#4 Re: BOMs for UTF-8 and UTF-16
Posted by: pspad | Date: 2014-01-30 05:51 | IP: IP Logged
I don't understand, what you want to do.
If you want to save file in UTF-8 without BOM, go to program settings / Program 2 and switch off include BOM in UTF-8
#5 Re: BOMs for UTF-8 and UTF-16
Posted by: tmpad | Date: 2014-01-30 17:42 | IP: IP Logged
I create a UTF-8 encoded text file with another program.
I load that file into pspad; the status line says UTF-8.
I switch to "View | Hex Edit MODE".
The status line still says UTF-8, but the hex display starts with a UTF-16 LE BOM.
In Hex Edit MODE, the status line must read "UTF-16 LE" and should not show a BOM.
BOMs are used to tell other programs about the encoding of text files. When showing a hex view of data in the memory, a BOM is obsolete. The program knows about the encoding.
