You are here: PSPad forum > English discussion forum > Unicode letters create incorrect cursor offsets
Posted by: skibulk | Date: 2014-01-16 03:29 | IP: IP Logged
Given the following text (one line):
136725 1 11461 801 8 こだまの魔道士 "クリーチャー ― 人間・ウィザード" "Lvアップ {1}{U} ({1}{U}:この上にLvカウンターを1個置く。Lvアップはソーサリーとしてのみ行う。)Lv 2-32/4{U}{U}, {T}:インスタント呪文1つかソーサリー呪文1つを対象とし、それをコピーする。あなたはそのコピーの新しい対象を選んでもよい。Lv 4+2/5{U}{U}, {T}:インスタント呪文1つかソーサリー呪文1つを対象とし、それを2回コピーする。あなたはそれらのコピーの新しい対象を選んでもよい。" "Matt Stewart" 32 43/356 COM13_R B N R
When I place the mouse cursor in the middle of the string, the cursor is actually several characters ahead of the character displayed at that position.
So if I want to add or remove characters, I cannot just click where I want to begin editing...
Using PsPad 4.5.7 with monospaced fonts.
Edited 1 time(s). Last edit at 2014-01-16 03:30 by skibulk.
Posted by: pspad | Date: 2014-01-16 06:05 | IP: IP Logged
The ruller doesn't count with width of japanese characters
Same problem will be with chinese chars.
Posted by: vbr | Date: 2014-01-16 08:00 | IP: IP Logged
skibulk:Given the following text (one line):
I guess, this is not only a problem with the ruler (which indeed doesn't count these characters correctly), but also with the editing (not necessarily on double-width characters).
You can try to experiment with the settings for whitespace, which sometimes caused problems in some contexts/ fonts etc., especially with numbers.
Try to change:
Settings: Program settings: Direct edit:
[Special settings]
OldSpecialChars=1
or
OldSpecialChars=0
You chan possibly check whether linewrapping doesn't influence this behaviour.
