You are here: PSPad forum > English discussion forum > C# in Code Explorer not working correctly
Posted by: mrGizmo | Date: 2014-01-14 21:36 | IP: IP Logged
I searched the PsPad forum and found several people who have requested help however I didn't see any one that addressed the problem. C# in the Code window doesn't pull any methods/functions like it used to years ago, it pulls classes, namespaces and defines but has lost it's ability to get the functions. I looked at the syntax ini and compared it to others and the only thing I could see is that had relevance was the line CodeExplorer=ftCSharp, however I don't see a way to edit or adjust it. What I'm looking for is something like the below sample: (This is mangled due to formatting I'm hoping you'll get the gist of what the
Quote:Hierarchical Code TreeView
TestSample {NameSpace - Level 1 deep}
CommandManager {Class - Level 2 deep}
ExecuteCommand {Method/function in Class - Level 3 deep}
Undo {Method/function in Class - Level 3 deep}
EndDisableCommands {Method/function in Class - Level 3 deep}
BeginDisableCommands {Method/function in Class - Level 3 deep}
ClearHistory {Method/function in Class - Level 3 deep}
Command {Class - Level 2 deep}
RangeInfo {Class - Level 2 deep}
PlaceStart {Method/function in Class - Level 3 deep}
PlaceEnd {Method/function in Class - Level 3 deep}
Which code wise would look something like the below:
using System.Collections.Generic;
using System;
namespace TestSample
internal class CommandManager
public void ExecuteCommand(Command cmd)
public void Undo()
private void EndDisableCommands()
private void BeginDisableCommands()
internal void ClearHistory()
internal abstract class Command
internal class RangeInfo
public PlaceStart { get; set; }
public PlaceEnd { get; set; }
I have used this application for years and donated to this project, it would be nice if this could be resolved. Any ideas would be appreciated.
Posted by: pspad | Date: 2014-01-15 05:08 | IP: IP Logged
Thank you for example. I will try to fix it.
Posted by: mrGizmo | Date: 2014-01-17 15:14 | IP: IP Logged
Thanks for help!
Posted by: mrGizmo | Date: 2014-03-05 18:39 | IP: IP Logged
Can you let me know when you've resolved this and I will test it for you.
Regards,
Posted by: pspad | Date: 2014-03-05 20:24 | IP: IP Logged
I am sorry for delay. I know it takes a long time, but I am very busy in my work now.
Posted by: mrGizmo | Date: 2014-04-17 17:30 | IP: IP Logged
Thanks for your time, just a FYI this worked in a previous version 4.5.5 (2417). For some reason this stopped working somewhere later down the pipe. Thought this might help.
Regards,
