You are here: PSPad forum > English discussion forum > Order
Posted by: Esgrimidor | Date: 2014-01-12 16:16 | IP: IP Logged
How can I order a list of lines with words in :
1. Alphabetically order
2. Inverse Alphabetically order
3. Alleatory order
Best Regards
Nice program indeed
Posted by: pspad | Date: 2014-01-12 16:32 | IP: IP Logged
1 and 2 - use function from the menu Edit / Sort
PSPad doesn't contains random order. But it can be partially simulated if you will use Sort function and let PSpad sort your words using column - e.g. position 3-5
Posted by: Esgrimidor | Date: 2014-01-12 22:47 | IP: IP Logged
Understood.
It's a good solution for a special case.
Best Regards
Nice program indeed
