You are here: PSPad forum > English discussion forum > Add new file types to existing Highlighter
Posted by: florianmuellerCH | Date: 2014-01-02 11:39 | IP: IP Logged
Hi PSPad Community
I am working right now with a small scripting language that has quite much parallels to PHP, and this is why the PHP syntax highlighter fits quite well.
Now I want to achieve that the PHP syntax highlighter is automatically chosen when such a file gets opened. I tried adding the new file extension at "Settings > Highlighter settings > PHP > Specification", but this actually takes only effect in the save dialog (available extensions), but the syntax highlighter won't automatically work.
EDIT: It works correctly if I create a new file (Ctrl + N) and then click on PHP.
What do I else have to do?
Thank you in advance for your help!
Edited 1 time(s). Last edit at 2014-01-02 11:42 by florianmuellerCH.
Posted by: vbr | Date: 2014-01-02 12:01 | IP: IP Logged
florianmuellerCH:Hi PSPad CommunityI am working right now with a small scripting language that has quite much parallels to PHP, and this is why the PHP syntax highlighter fits quite well.
I believe, it should work with the settings you made, e.g. adding an item in File Mask
in Settings > Highlighter settings > PHP > Specification
like
*.someextension
(and possibly newline at the end of the list)
Another possible issue might be the file size limit for automatic highlighting on opening
If your files are bigger, you can increase this limit in
Settings: Program settings: [Direct edit]: Special settings:
HLOnUpToSize=...
hth,
Posted by: florianmuellerCH | Date: 2014-01-10 14:33 | IP: IP Logged
I'll give that with the newline a try this evening.
But the files I'm trying to open aren't that big.
Could it possibly be that the extension is somehow already entered at another highlighter? I'm trying to add the extension *.sqf to the PHP highlighter...
Thank you for your help!
Florian
Posted by: pspad | Date: 2014-01-10 18:33 | IP: IP Logged
Send some screenshot. When you save highlighter settings and go there again, if your new extension there?
