You are here: PSPad forum > English discussion forum > Re: User-Highlighter like INI highlighter possible?
Posted by: fly | Date: 2013-12-31 09:13 | IP: IP Logged
I would like to generate a USER highlighter which extends the INI hightlighter.
How can I do this?
(I tried "CodeExplorer=ftINI", but it does not help - I am never able to specify the colour / font for "Section" ("Settings" - "Highlighter settings")- as it is possible for the INI highlighter)
(I think, generally, it would be very helpful, if the folder "Programs/PsPad Editor/Syntax" you would present an "extension"/"example" for each of the "standard" syntax highlighters - e. g. you could call them "INI-Example", "CPP-Example", ... or "INI-Extension", "CPP-Extension", ... - at least for such very widely used extensions like INI I think this would be helpful for many people).
Edited 2 time(s). Last edit at 2013-12-31 09:23 by fly.
Posted by: pspad | Date: 2013-12-31 12:02 | IP: IP Logged
There are 2 kinds of highlighters - internal - hard programatically made and user highlighters.
User highlighter can't have possibility of the hard coded highlighter.
Can you tell me what do you want to extend?
