You are here: PSPad forum > English discussion forum > Re: Spaces in paths or file names
Posted by: PGomersall | Date: 2013-12-24 17:49 | IP: IP Logged
Jan,
I am sorry if this is already posted somewhere, but I have looked through the FAQ's and the searched the forums.
It seems that if there is a space in a path or a file name PSPad displays the path and or filename in dos style.
Is there a way to make PSPad show the path or filename with the space (i.e. Windows style)or is this to prevent problems interacting with compilers\programming tools?
Regards,
Pete
Posted by: pspad | Date: 2013-12-24 18:03 | IP: IP Logged
Where exactly space in file name causes this problem? In compiler or external applications settings or if you run PSPad with file name as parameter?
Posted by: PGomersall | Date: 2014-01-13 18:35 | IP: IP Logged
Jan,
I tracked this down to the setting in the registry having the full path rather than DOS path:
[HKEY_CLASSES_ROOT\*\shell\PSPad\Command]
@="C:\\Program Files (x86)\\PSPad\\PSPad.exe \"%1\""
@="C:\\PROGRA~2\\PSPad\\PSPad.exe \"%1\""
Posted by: pspad | Date: 2014-01-13 18:59 | IP: IP Logged
Settings in the registry can't have influence of the file name inside PSPad. It's path from where to start PSPad only.
But quotes in your path are strange. PSPad name should be surrounded without spaces, followed by space and %1 should be surrounded without spaces too
