You are here: PSPad forum > English discussion forum > Google Search
Posted by: x-15a2 | Date: 2013-12-12 18:54 | IP: IP Logged
Is there any way for users to replace Google with the search engine of their choice in the PSPad "Google Search" function? I prefer not to be tracked by G!.
Posted by: pspad | Date: 2013-12-13 09:37 | IP: IP Logged
No, it isn't possible now.
Any engine has own syntax and own possibilities. You can simply write your own internet search using PSPad scripting capabilities
I will try to investigate posibilities of other engines. What global engine do you suggest to use instead of google?
Posted by: carbonize | Date: 2013-12-14 09:50 | IP: IP Logged
Not sure why you have the ability to change which Google gets used since they automatically redirect you to your local one anyway.
As to other search engines.
DuckDuckGo - duckduckgo.com
Bing - www.bing.com
Yahoo - search.yahoo.com (Yahoo!uses Bing for results anyway)
Carbonize
