You are here: PSPad forum > English discussion forum > Re: Update
Posted by: Asal | Date: 2013-11-23 21:13 | IP: IP Logged
after long time using PSPad 4.5.4, I decided to update to the current 4.5.7 now. But I did many changes at PSPad: Templates, Clips, Batches, ... Of course, I do not want to loose my settings.
So I copied the new pspad.exe into my old directory, and the new language.ini, too. Seems to work fine.
Is there anything else recommended, I should add/update?
Martin
Posted by: pspad | Date: 2013-11-24 07:49 | IP: IP Logged
Update your old installation by new PSPad.exe and new Lang subfolder only.
The rest you can keep from your old installation.
