You are here: PSPad forum > English discussion forum > Export as Email
Posted by: KenB | Date: 2013-11-05 04:52 | IP: IP Logged
I have Outlook 2010 installed. I am unable to export as email. I do not get an error displayed, nothing happens. Any ideas on how to fix this?
Posted by: pspad | Date: 2013-11-05 05:05 | IP: IP Logged
Go to program settinsg / Internet
Check is proper mail client is set there
Posted by: KenB | Date: 2013-11-05 19:05 | IP: IP Logged
Thank you. That worked.
I had checked "Use my Default E-Mail Client". That seems like it should have worked.
I unchecked "Use my Default E-Mail Client", and then selected "Microsoft Outlook" from the dropdown. That fixed it for me.
Posted by: pspad | Date: 2013-11-05 19:21 | IP: IP Logged
Sometimes "default client" in Windows isn't what you awaited.
To fix it, you can set Outlook as defalt client somewhere in Outlook settings or from the other side - use default application from the Widnows start menu. Even Outlook is set as default, change it, confirm and change it back. It usually fix default settings
Posted by: pythonui | Date: 2015-05-06 10:40 | IP: IP Logged
Shortcut for Export as Email?
Posted by: pspad | Date: 2015-05-06 10:49 | IP: IP Logged
pythonui:Shortcut for Export as Email?
Program settings / Key map
Click on the group "Send"
Assign shortcut for Export as e-Mail
