You are here: PSPad forum > English discussion forum > Disconfiguration . What can I do ?
#1 Disconfiguration . What can I do ?
Posted by: Esgrimidor | Date: 2013-10-31 12:13 | IP: IP Logged
The line format has changed.
Is shortened to few characters and I don't know how to correct.
So is the usual thing is 80 characters or so I have less and the line is truncated.
What can i do
Best regards from canary islands
Nice program indeed
#2 Re: Disconfiguration . What can I do ?
Posted by: vbr | Date: 2013-10-31 12:29 | IP: IP Logged
Esgrimidor:
you can set the line width (as shown with line-wrapping active) in
Settings: Program settings: Editor (part 2): Position of right edge:
It is also possible to change this value by clicking at the appropriate position of the ruler (menu: View: Ruler)
hth,
#3 Re: Disconfiguration . What can I do ?
Posted by: pspad | Date: 2013-10-31 14:43 | IP: IP Logged
Switch off wordwrap mode (Ctrl+W) or toolbar button or menu View
#4 Re: Disconfiguration . What can I do ?
Posted by: Esgrimidor | Date: 2013-11-01 17:47 | IP: IP Logged
It's only in one tab. The rest go well.
So I don't see the options configuration as an answer
Best Regards
Nice program indeed
#5 Re: Disconfiguration . What can I do ?
Posted by: Esgrimidor | Date: 2013-11-01 17:54 | IP: IP Logged
vbr:
Esgrimidor:
hth,
Now I have understand.
Best Regards
Nice program indeed
#6 Re: Disconfiguration . What can I do ?
Posted by: Esgrimidor | Date: 2013-11-01 18:11 | IP: IP Logged
Understood
Best Regards
Nice program indeed
