You are here: PSPad forum > English discussion forum > Splitting a very large txt file into smaller ones
#1 Splitting a very large txt file into smaller ones
Posted by: d.coles@soton.ac.uk | Date: 2013-10-24 15:42 | IP: IP Logged
I am new to PSPad and am looking for a way of splitting up a very large txt file (2.5 million rows, 3 columns) into smaller more managable txt files with the same number of columns but less rows. I saw something online about using the copy feature in the find dialog, which can be accessed from the search tab, however I cannot work out how to use it.
Any help would be greatly appreciated.
Kind Regards
Daniel
#2 Re: Splitting a very large txt file into smaller ones
Posted by: pspad | Date: 2013-10-25 06:22 | IP: IP Logged
I see the way only using PSPad scripting:
set position to start
move and select e.g. 100 000 lines
open new file, copy it there, save
repeat it to end of file
#3 Re: Splitting a very large txt file into smaller ones
Posted by: Stefan | Date: 2013-10-25 17:37 | IP: IP Logged
For such large files, better use a dedicated tool like www.hjsplit.org
#4 Re: Splitting a very large txt file into smaller ones
Posted by: Donna111 | Date: 2013-10-31 01:53 | IP: IP Logged
HI there
For me ,i usually split the word text file using this text split program:
www.rasteredge.com
It supports to split the large file into smaller one.But i have only tried the free trial.It's effective.Hope to help you.
