You are here: PSPad forum > English discussion forum > how to add a comment block by shortcut
Posted by: actino | Date: 2013-10-04 07:59 | IP: IP Logged
Hi dudes
I returned back to win/pspad - and i can remember that i used a shortcut to insert predefined text. but i cant find the solutions - many thanks for any helps
example:
> press own defined shortcut
> insert predefined text on open file
> ex:
// Description: foo bar bla bla
// Developer: foooo.baaar@bla.ch
// Time: <date> (optional)
i think its so basic work - that i cant find the right words on google...
SO THANKS FOR YOUR HELP!
greeets action
Posted by: pspad | Date: 2013-10-04 11:58 | IP: IP Logged
This isn't block comment but line comments inserted on each line.
Use functionality from the format menu - Add/Remove format (Shift+Ctrl+A) on selected block
If you insist on your "block format" functionality, use PSPad scripting abilities and write simple script what will be applied on selected code
Posted by: pspad | Date: 2013-10-04 11:59 | IP: IP Logged
If you want to use it for Header, you can use Code clips (Ctrl+Space)
It's easy to write new clip and insert there using user variables your name, date e.t.c.
See the interactive code clips in the PSPad help
