You are here: PSPad forum > English discussion forum > Re: How to run vbscripts from within pspad
Posted by: pudnik | Date: 2013-09-12 23:01 | IP: IP Logged
Hello, I'm sorry if this has already been covered but I searched the forums twice and nothing came up.
If one is editing a vbscript from within PSPad, how does one setup a custom menu item or button to run that vbscript from within the editor?
thank you
pudnik
Posted by: pspad | Date: 2013-09-13 03:54 | IP: IP Logged
Use PSPad scripting support - you can extend PSPad abilities with custom script - in this case you can call it from menu script where new item appear.
Ensure the Scripting support is enabled in Program settings / System
You can call any external application include CScript using external application or compiler in highlighter settings (depends of syntax) or from the favorite panel - syntax independant
Posted by: pudnik | Date: 2013-09-13 19:15 | IP: IP Logged
OK...I'm almost sure that someone has already written a script for this, is there a PSPad script repository where I can search for it? Or is there a tutorial somewhere? I'm a programmer so I just need a little hint and I can do it...
Posted by: pspad | Date: 2013-09-13 19:31 | IP: IP Logged
There is lot of scripts for many different things - see the subfolder Script\JScript
You can download many other script from the PSPad extension page
I don't know what you want to do.
To run totally external script setup external application - cscript with your external script as parameter
Posted by: vbr | Date: 2013-09-13 19:35 | IP: IP Logged
pudnik:OK...I'm almost sure that someone has already written a script for this, is there a PSPad script repository where I can search for it? Or is there a tutorial somewhere? I'm a programmer so I just need a little hint and I can do it...
various user-supplied scripts can be found on the homepage:
www.pspad.com
There is a file with api reference and some examples in
...\PSPad\Script\ReadMe.rtf
There might be some script samples as well directly in
...\PSPad\Script\VBScript\
(where you also will place the VBscripts for PSPad (assuming you are looking for internal editor scripting, rather than e.g. calling external scripts from the editor.)
hth,
Posted by: pudnik | Date: 2013-09-17 00:44 | IP: IP Logged
Let me be more specific.
For example, if you open a WSH script in VBSedit, an IDE which you have to buy and is not portable, you can click on the START button, and VBSedit will execute the script that you are editing.
In PSPad, in Settings | System Integration, I have the Integrated scripting support (WSH) checkbox checked.
If I have a WSH script loaded into PSPad, how can I create a RUN button that will execute it using Wscript.exe
Edited 1 time(s). Last edit at 2013-09-17 00:45 by pudnik.
Posted by: pudnik | Date: 2013-09-17 01:05 | IP: IP Logged
...OK, OK, I found the button. VBScripts are interpreted, not compiled, but if you click on the "Run external compiler to compile file", it will do what I want.
