You are here: PSPad forum > English discussion forum > Re: Automatic capitalisation of keywords
#1 Automatic capitalisation of keywords
Posted by: slowfiddler | Date: 2013-09-08 21:50 | IP: IP Logged
Is it possible to get PSPad to automatically capitalise keywords as they are entered? I know this can be done manually from Format/Code Case Change...
Even better would be if you could add functionality that copies the capitalisation from the keyword definitions in the syntax .INI file.
While I am posting, is multiline comment highlighting possible? For example
this is
a
multiline
comment
Great editor. Really makes working with PIC assembler a breeze, especially as I can invoke the assembler from PSPad.
Thanks.
Edited 1 time(s). Last edit at 2013-09-08 21:52 by slowfiddler.
#2 Re: Automatic capitalisation of keywords
Posted by: pspad | Date: 2013-09-09 03:46 | IP: IP Logged
Automatic capitalization is possible using Autocorrection list. You need to fill up list with capitalized keywords.
Multiline comment depends of syntax. Not every syntax support it and each syntax uses own comment chars.
