You are here: PSPad forum > English discussion forum > Log windows not displaying output from XSLT
Posted by: xymox12 | Date: 2013-08-29 13:03 | IP: IP Logged
Hi
I have set up a PSPad Project with my xml and xsl file only. I then setup the project compiler to use a command line xsl tool and output to the Log window. This way I can use PSPad as a good xsl development tool using a split view so I can view both files side by side, along with the code explorer.
But... whatever commandline tool I use, most of the characters of the XSLT output are returned as whitespace/blank to the Log Window. Which ain't good. Any ideas?
One 'compiler' is saxon9he.jar and is launched, in my case, via portable java. The settings I use for the compiler:
Compiler: Java/bin/java.exe
Parameters: -jar saxon9he.jar %Name%%ext% %Name%%ext%
I have also use msxsl and xsltproc in testing. I have my own xml/xsl but have also tried the code at www.w3schools.com
I can get a very similar setup to work in notepad++ using nppexec and its console window, but I would prefer to stick with PSPad.
Cheers
Posted by: pspad | Date: 2013-09-17 11:11 | IP: IP Logged
You have 2 possibilities to display compiler output.
1. catch compiler output will catch console output
2. let compiler write log into file and display the file by filling in Log file field
