You are here: PSPad forum > English discussion forum > vbScript with HKCU regkey when UAC is activated
Posted by: TrywareDk | Date: 2013-08-29 08:46 | IP: IP Logged
I’m trying to make a silent vbScript installscript for PsPad on Windows 7 32 bit
UAC is activated on the ’normal users’ account, and the user isn’t local administrator, but knows another local administrator logonname when UAC is elevated, or a file is rightclicked, and ’run as administrator’ is selected.
The scenario works fine with my vbScript (when it’s UAC-elevated), PsPad is installed and works, except that I want in my vbScript to add some extra HKEY_CURRENT_USER settings, but they are imported into the ’another local administrator’ HKCU, and NOT the ’normal user’, that’s supposed to use PsPad.
So when running the following in my silent install vbScript, nothing happens for the ’normal user’:
C:\Windows\regedit.exe –s C:\Setup\HKCU-PsPad.reg
Do you know any solution to this, because I expect you might have had the same problem when you created your own installer
Sincerely
J. Malmgren
IT-Programmer
www.tryware.dk
