You are here: PSPad forum > English discussion forum > Support of Less (lesscss)
Posted by: erational | Date: 2013-08-09 03:40 | IP: IP Logged
hello
i try to integrate lessCSS (http://www.lessorg.org) in pspad to get the syntax highlight.
the lessCSS syntax is a extension of CSS langage (integrated in the core and not as a extension)
so i try to add in PSPAD.INI but it does work
[Cascading Style Sheet]
Filter=Cascading Stylesheets (*.css;*.less)|*.css;*.less
would be possible to get the CSS syntax file to add less specific syntaxe (such as variables or functions)
thank you.
Posted by: pspad | Date: 2013-08-09 08:13 | IP: IP Logged
As I see there is no necessary to do any modification. Standard CSS highlighter is able to highlight lesscss as well.
If there are different file types for lesscss, go to highlighter settings / Cascaded style sheets and add new extensions there
Posted by: erational | Date: 2013-08-14 04:26 | IP: IP Logged
it works fine. thank you !
