You are here: PSPad forum > English discussion forum > Start PSPAD with CLI & open FTP
Posted by: MatthijsG | Date: 2013-07-08 10:15 | IP: IP Logged
Hi all,
Is it possible to start PSPAD with a FTP-connection connected using the command line? This info isn't enough gogogadgetscott.info and the Script-info isn't also clear .. However, i can see that it's possible to open a FTP-connection with scripting.
Posted by: pspad | Date: 2013-07-08 14:05 | IP: IP Logged
There is no possibility to use command line to open FTP connection
But there is possibility to use scripting to open it.
Each script has INIT() function what is called each time script is recompiled (on the start too). This is the place you can use for connection to your FTP - test if connection is active and if not, connect it.
