You are here: PSPad forum > English discussion forum > Re: Login authentication failed
Posted by: m.jablonska1996 | Date: 2013-06-11 21:01 | IP: IP Logged
22:54:48 >> Connecting to: cba.pl
22:54:48 << 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
22:54:48 << 220-You are user number 74 of 200 allowed.
22:54:48 << 220-Local time is now 22:54. Server port: 21.
22:54:48 << 220-This is a private system - No anonymous login
22:54:48 << 220-IPv6 connections are also welcome on this server.
22:54:48 << 220 You will be disconnected after 2 minutes of inactivity.
22:54:48 >> USER ''.phorum_html_encode('admin@oazakety.cba.pl').''
22:54:49 << 331 User ''.phorum_html_encode('admin@oazakety.cba.pl').'' OK. Password required
22:54:49 >> PASS xxxxx
22:54:55 << 530 Login authentication failed
22:54:55 << 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
22:54:55 << 220-You are user number 75 of 200 allowed.
22:54:55 << 220-Local time is now 22:54. Server port: 21.
22:54:55 << 220-This is a private system - No anonymous login
22:54:55 << 220-IPv6 connections are also welcome on this server.
22:54:55 << 220 You will be disconnected after 2 minutes of inactivity.
22:54:55 >> USER ''.phorum_html_encode('admin@oazakety.cba.pl').''
22:54:55 << 331 User ''.phorum_html_encode('admin@oazakety.cba.pl').'' OK. Password required
22:54:55 >> PASS xxxxx
22:54:59 << 530 Login authentication failed
22:54:59 >> Can't connect
22:54:59 >> LastError: 0
What should I do?
Posted by: Stefan | Date: 2013-06-12 11:09 | IP: IP Logged
Please, what has this to do with PSPad advanced text editor?
Posted by: m.jablonska1996 | Date: 2013-06-12 12:04 | IP: IP Logged
It's a problem with this "advanced editor"...
Posted by: Stefan | Date: 2013-06-12 13:17 | IP: IP Logged
Then provide more details. My crystal bowl is broken...
Posted by: carbonize | Date: 2013-06-12 21:03 | IP: IP Logged
And you have made sure you are using the right username and password? Test with Filezilla or some such.
Carbonize
Posted by: m.jablonska1996 | Date: 2013-06-13 18:10 | IP: IP Logged
Yes, I use right login and password.
Posted by: pspad | Date: 2013-06-13 19:32 | IP: IP Logged
m.jablonska1996:Yes, I use right login and pIassword.
It means if you will use another FTP client, you can connect?
What you sent, is communication log with FTP server. You sent user name and password to server, server compare data with stored user name and password and found they don't match.
The result is: Login authentication failed.
Cause the user was accepted correctly, there is problem with password.
