You are here: PSPad forum > English discussion forum > how to put blanks into the first column of a file
Posted by: enricoernesto | Date: 2013-05-30 08:00 | IP: IP Logged
can anyone tell me, how I can put blanks into the first column of a file with extension .asm?
Thank You very much for help!
enricoernesto
Posted by: pspad | Date: 2013-05-30 08:37 | IP: IP Logged
Select text and use function Insert text to lines (alt+I)
or
set tabwidth to 1
select text and press tab
or
use search replace dialog
search: (.*)
replace: $1 (there is space before $1)
[x]regular expression
Edited 1 time(s). Last edit at 2013-05-30 08:40 by pspad.
