You are here: PSPad forum > English discussion forum > Highlighter Table Name
Posted by: Anonymous User | Date: 2013-05-23 11:50 | IP: IP Logged
Two issues:
1) What is the intended use in 'Settings/Highlighter Settings' (for SQL (Oracle)) the various options for 'Table Name'? I thought it should be used in conjunction with, by me, given Oracle table names, but not so.
2) Can you please add the reserved word 'triggers' to the above mentioned syntax highlighter?
Edited 1 time(s). Last edit at 2013-05-23 11:50 by Skulstad.
Posted by: pspad | Date: 2013-05-23 12:45 | IP: IP Logged
1) Table name - user wish
2) TRIGGERS added as Oracle keyword
Posted by: Anonymous User | Date: 2013-05-24 05:29 | IP: IP Logged
1) I still do not see how to use it ...?
Posted by: pspad | Date: 2013-05-24 05:39 | IP: IP Logged
I don't remember it yet without looking into program. I guess it's used in Create/alter Table e.t.c.
Posted by: Anonymous User | Date: 2013-05-24 12:01 | IP: IP Logged
Hi.
2) Please also add 'degree' and 'instances'.
Posted by: pspad | Date: 2013-05-24 12:20 | IP: IP Logged
Skulstad:2) Please also add 'degree' and 'instances'.
Should I add it into TSQL keywords or PL/SQL.
I looked into highlighter for Table names attribute. It's prepared for external list of table names from highlighter authors. I don't see ussage in PSPad
Posted by: Anonymous User | Date: 2013-05-27 05:41 | IP: IP Logged
Hi. It's part of the 'create table' in Oracle, like:
CREATE TABLE bbas.tt_innvandring
PARALLEL (DEGREE DEFAULT INSTANCES DEFAULT)
