You are here: PSPad forum > English discussion forum > runtime error 204
runtime error 204
#1 runtime error 204
Posted by: ulib | Date: 2013-05-08 10:00 | IP: IP Logged
hello,
i use PsPad since a long time with no problem.
(Windows XP, SP3, all Windows-Updates, german language)
But now i have 2 problems:
- after starting PsPad i got a error message box popped up 'Support for "Jscript" support not found! Install WSH with requestet language support.'. i make no changes at my system or install new software !
- when i finished PsPad the popped up a message box "Runtime error 204 at 00402B68"
i have updated PsPad to the actual version, but the 2 problems are still there !!!
greetings
Ulrich Becker
Edited 1 time(s). Last edit at 2013-05-08 10:07 by ulib.
#2 Re: runtime error 204
Posted by: pspad | Date: 2013-05-08 10:08 | IP: IP Logged
There is necessary to allow local scripting in the Internet settings
If you don't use PSPad scripting support, do to program settings / System integration and disable scripting support there. Restart PSpad.
#3 Re: runtime error 204
Posted by: ulib | Date: 2013-05-08 14:36 | IP: IP Logged
thanks,
problem is gone smiling smiley
