You are here: PSPad forum > English discussion forum > Is there a block mode (hotkey)?
#1 Is there a block mode (hotkey)?
Posted by: pstein | Date: 2013-05-05 13:19 | IP: IP Logged
I often need an editor for block mode operations.
That mean I want to mark/delete/copy e.g. all columns from 12 to 27 from lines 23 to 40.
For that I would like to invoke a block mode by hotkey e.g. ALT.
When I press the hotkey and use the mouse a vertical block line/area
should be marked.
Is this possible in PsPad?
If yes: How exactly?
Is it possible to assign the ALT as hotkey to block mode=ON
Peter
#2 Re: Is there a block mode (hotkey)?
Posted by: pspad | Date: 2013-05-05 13:43 | IP: IP Logged
Pspad work this way. Go to program settings / editor and allow ALT sets column mode
#3 Re: Is there a block mode (hotkey)?
Posted by: pstein | Date: 2013-05-05 14:21 | IP: IP Logged
Ah, ok, thank you.
BUT: When I use the column mode then at least ONE full column must be marked.
What, if I want to insert an "a" between column 7 and 8 for multiple lines?
I cannot mark a column of width=0 (= just specify insert position).
I expected in that case to appear just a vertical line. But there is none.
How do I handle this situation?
Peter
#4 Re: Is there a block mode (hotkey)?
Posted by: pspad | Date: 2013-05-05 14:49 | IP: IP Logged
You can use insert text to lines (alt+i) function
#5 Re: Is there a block mode (hotkey)?
Posted by: pstein | Date: 2013-05-12 10:23 | IP: IP Logged
Ok, so there is no visual vertical line for block mode like it appears e.g. in Notepad++?
#6 Re: Is there a block mode (hotkey)?
Posted by: Stefan | Date: 2013-05-13 19:56 | IP: IP Logged
pstein:
No.
