You are here: PSPad forum > English discussion forum > Re: How to comment out the whole statements with pspad software?
Posted by: sjzrifdsa | Date: 2013-05-04 09:39 | IP: IP Logged
hello!How to comment out the whole statements with pspad software? Thank you!
Posted by: pspad | Date: 2013-05-04 09:50 | IP: IP Logged
Select statemend and use comment/uncomment from menu format for each line comment in selection.
If your language supports multiline comment, use ctrl+space and choose comment
Posted by: sjzrifdsa | Date: 2013-05-04 10:05 | IP: IP Logged
How to comment out the whole apdl code block? Thank you!
Posted by: sjzrifdsa | Date: 2013-05-04 10:09 | IP: IP Logged
hello! I press the Ctrl+Shift+A, but there is no response.
(Shift+Ctrl+A) does not add anything in front of each line. Why? Thank you!
Edited 1 time(s). Last edit at 2013-05-04 10:15 by sjzrifdsa.
Posted by: carbonize | Date: 2013-05-04 10:35 | IP: IP Logged
What language is the file you are trying to comment in? Obviously file types such as txt do not have a comment type and so this function will do nothing.
Carbonize
