You are here: PSPad forum > English discussion forum > Re: HTML 5
Posted by: djrooman | Date: 2013-04-25 10:52 | IP: IP Logged
Hi, do You plan adding HTML 5 tags while using autocomplete (Ctrl + Space)?
I mean tags like: section, header, footer, etc.
Edited 1 time(s). Last edit at 2013-04-25 11:50 by djrooman.
Posted by: pspad | Date: 2013-04-25 13:54 | IP: IP Logged
Do you use the current PSPad version?
Posted by: pspad | Date: 2013-04-25 13:58 | IP: IP Logged
Can you send me list of HTML 5 tags what was added? I can modify context help file.
Anyway, it's easy to modify it.
See .\Context\html.def
It's a plain text file, syntax is described in PSPad help
Posted by: Manfred62 | Date: 2013-04-25 16:00 | IP: IP Logged
there are HTML5 files in the extension area
Quote:HTML 5 (Marshall)
Color, Context, Syntax and Template for HTML 5 (Beta)
also you can use Emmet. That's a script with nearly all features needed for webdevs.
PSPad 4.5.9 (2525)
