You are here: PSPad forum > English discussion forum > ftp problem with "subtree"
Posted by: u8721019 | Date: 2013-04-17 02:41 | IP: IP Logged
i want to use pspad to edit remote files,
however, i loggin and no files shown
I checked my notepad++ setting,
"On connection, subtree root folder"
then everything goes well...
i cant find where to set this up.
could anyone help me about this? thx in advance!
Posted by: pspad | Date: 2013-04-17 05:19 | IP: IP Logged
Some suggestion:
Use latest PSPad version
In FTP connection settings:
Uncheck Show hidden files
Check passive mode
Check compatible mode
Uncheck TLS/SSL
If it doesn't help, connect to your FTP server, show Log window (Ctrl+L)
Press LIST button on the left side in the log window
Send me result to support mail as TXT atachment (you can use Mail FTP log function)
I need raw LIST output
