You are here: PSPad forum > English discussion forum > register as HTML viewer
Posted by: antipop | Date: 2013-04-16 19:15 | IP: IP Logged
I would like to try using PSPad as an HTML viewer program in IE, but I am having a problem. The system is 64-bit Windows 7 Professional with Internet Explorer 10 installed. I used the setting in PSPad from the Settings menu > Program Settings and put a check in "Register in IE as HTML viewer." I supposed after doing so that this would allow me to use PSPad to open HTML files when I use "Open With" in the Windows Explorer context menu from a right-click. How else was it intended as an HTML viewer if not in this way? It does not appear to work. Any ideas?
Posted by: pspad | Date: 2013-04-16 19:25 | IP: IP Logged
Any version of IE brings changes. Do it using Internet settings dialog.
