You are here: PSPad forum > English discussion forum > PSPad Macro Commands
Posted by: ralfehr | Date: 2013-02-19 14:24 | IP: IP Logged
When trying to write a macro to delete dates in a column I tried to use the ecGotoXY macro command. It is supposed to move the cursor to coordinates XY but I can't find a way to give it the specific coordinates. Does anyone know how to use this macro command?
Posted by: pspad | Date: 2013-02-19 14:59 | IP: IP Logged
Macro records movement. You can move to position but not jump there
Posted by: ralfehr | Date: 2013-02-19 15:58 | IP: IP Logged
Can you give an example of how to use the ecGotoXY macro command?
Posted by: pspad | Date: 2013-02-19 19:31 | IP: IP Logged
I wrote you, you can't use GotoXY, cause this command needs arguments. You can use several left/right and up/down to navigate where you need.
