You are here: PSPad forum > English discussion forum > Re: PSPAD files opened with other TEXT editors look like HEX
Posted by: Linnemeyer | Date: 2013-02-18 23:46 | IP: IP Logged
I have used PSPad for several years and have never had an issue when opening files created / saved from PSPAD with other text editors.
Not sure what I changed but now the files I create in PSPad when opened by another editor like notepad, appear to be hex code?
This is a disaster for me as everything I have checked into our source control is not not editable by other as I am the only one who uses PSPad.
I would love to continue using, but if I can't resolve this issue I will have to find something else. Bad part is I can't tell which of my many files that I have created in PSPad are like this unless I open them in another editor.
HELP
Posted by: pspad | Date: 2013-02-19 04:38 | IP: IP Logged
I guess you use PRC file extension.
Open all your files in PSPad, then open PSPad folder\Plugins\File extensions and delete PRC.DLL
Save all your files.
Edited 1 time(s). Last edit at 2013-02-19 04:38 by pspad.
