You are here: PSPad forum > English discussion forum > Re: Arguments to scripts
#1 Arguments to scripts
Posted by: kheops | Date: 2013-02-04 13:34 | IP: IP Logged
I wrote this little script in autoit :
; If 0 Params then exit
If $CmdLine[0] = 0 Then
MsgBox(8192, "Info","Give the Path")
Exit
EndIf
MsgBox(8192, "$CmdLine[1]","Path : " & $CmdLine[1])
At the end this script will be able to arrange file into "path" folders ...
But in pspad how to pass arguments (mine is path but it could be other things and/or multiple arguments) to scripts without editing everytime the highlighters Settings?
Thanks in advance grinning smiley
#2 Re: Arguments to scripts
Posted by: pspad | Date: 2013-02-04 13:56 | IP: IP Logged
You don't start Scripts in PSPad with arguments.
#3 Re: Arguments to scripts
Posted by: pspad | Date: 2013-02-04 14:00 | IP: IP Logged
If you want to know path of your file, get it using function in script.
#4 Re: Arguments to scripts
Posted by: kheops | Date: 2013-02-04 14:09 | IP: IP Logged
I was not clear ...
I dont run the script with pspapd but I run the interpreter ...(autoit)
One of the parameters of the interpreter is the name of the script but I want to send an argument to the script with PSPad...
#5 Re: Arguments to scripts
Posted by: kheops | Date: 2013-02-04 14:21 | IP: IP Logged
I finally remembered ....
just put %Input% at the end of the input line:
Settings
"AutoIT" (for me)
External Application
Application List
Application: "%%PSPath..\AutoIT\AutoIt3.exe" "%file%" %Input%
I remembered that I had already come across with this problem ...
I hope I have been of help to someone other than me ...tongue sticking out smiley
Edited 1 time(s). Last edit at 2013-02-04 14:24 by kheops.
