You are here: PSPad forum > English discussion forum > LOG Parser request/bug
Posted by: KennyT | Date: 2013-01-07 12:14 | IP: IP Logged
I've just discovered the joys of the log parser to enable lines with compilation errors to be quickly visited - great!
Spotted a bug though, in admittedly limited circumstances!
If:
1) I have two files open with the same name (but in different folders)
2) I compile one of the files that has errors
3) I select a different file (ie. neither of the two files above)
4) I then double click on the error line in the log...
It doesn't go to the correct file, almost as though the routine is only using the filename, not the full filepath? I'm using this mask:
* %F %L: *
to parse things like:
WARNING C:\wlib\qq_mainq.FOR 2563: 189: In a previous call to QT_TR, the first argument was of type CHARACTER(LEN=5), it is now REAL(KIND=1)
Only a minor niggle!
Tks
K
