You are here: PSPad forum > English discussion forum > Save scripts
Posted by: Lonestarjack | Date: 2013-01-04 16:02 | IP: IP Logged
All of a sudden I can not save any changed file; PHP or HTML.
I ran Uniblue Powersuite to cleanup my Windows 7 machine.
Posted by: pspad | Date: 2013-01-04 19:09 | IP: IP Logged
If you installed PSpad into program files, this is the reason.
No program has right to write into program files or Windows folder.
You can:
1. install PSPad outside of Program files
2. modify file access right to allow PSpad write into folder in Program files\PSpad
3. elevate PSpad access right - run PSPad with right mouse As administrator. This will allows you modify files in Program files folder. After modification, you can continue using PSpad without rights elevation
